It is currently Tue Jul 29, 2025 4:29 pm
PostPosted: Thu Apr 16, 2020 10:50 am
I’m setting up for another Neck angle jig job. I’ve been using a spacer that is 3.5 mm tall to place at the bridge to set the angle. It’s what I’ve always done. Is that pretty standard? It gives me the 1.5 deg pitch, but I wanted to double check:)
PostPosted: Thu Apr 16, 2020 4:16 pm
2.5mm drill bit (or 3/32") will get you .5" to .55" string height at the saddle with a .25" thick fretboard and .04" fret height. [:Y:]
